#1 Posted : Friday, December 1, 2017 6:28:28 AM(UTC)
Was thanked: 303 time(s) in 205 post(s)
Does anyone know how to swap the angle dimension around? Selecting the lines in a different order does not work, I want it to show 15 not 165. Thanks
Just tried it on a section view and managed to dimension how I sometimes to, however it's 1 degree more than is should be?
Windows 7 ViaCAD 10 Pro
Edited by user Friday, December 1, 2017 6:42:09 AM(UTC)  | Reason: Not specified
Todd Quinlan
#2 Posted : Friday, December 1, 2017 9:01:34 AM(UTC)
Todd Quinlan
If you want the dimension in the same place you could simply select the 165 dimension and replace the # in the text field of the data entry area with 15, but that will lose the association of the dimension to the angle itself.
(see image) You can draw a small line under the angle and use this to dimension. Then select the small line and from the edit menu remove the links, then delete it.
Todd Quinlan attached the following image(s):
Screenshot 2017-12-01 09.54.37.png (29kb) downloaded 0 time(s).
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
