Metin Seven
#1 Posted : Friday, November 24, 2017 2:55:53 AM(UTC)
Metin Seven
Netherlands
I've been viewing these mesh to NURBS conversion videos:
Video 1
Video 2
And I'm wondering what I should buy to be able to perform such conversions? I currently own ViaCAD 2D/3D v9 for MacOS.
The quad mesh preparation is no problem. I own both 3D Coat and ZBrush for quad retopology. Having said this, a successful method to convert triangular meshes to NURBS would be fabulous, if that exists too.
Many thanks in advance for your help.
Regards,
Metin
visualization • illustration • animation • 3D (print) design — metinseven.com
thanks 1 user thanked Metin Seven for this useful post.
GARLIC on 11/24/2017(UTC)
digitalphaser
#2 Posted : Friday, November 24, 2017 2:20:08 PM(UTC)
digitalphaser
There are many solutions to this problem. But usually this pleasure coast a lot of money. The simplest way for you is viaCAD Pro/SharkCAD + PowerPack Pro.
Some CAD editors are able to do it too. There is also a specialized software. For example: SubD2CAD or this small not expensive utility RESURF - OBJ mesh to solid. For a while I used it. Although it looks obsolete but it works well enough with a simple and clean quad mesh.
Metin Seven
#3 Posted : Monday, November 27, 2017 4:02:56 AM(UTC)
Metin Seven
Netherlands
Thanks for your reply, Digitalphaser, appreciated.
Is Powerpack Pro also compatible with ViaCAD 2D/3D? If not, what would it cost to upgrade my ViaCAD 2D/3D V9 to the latest ViaCAD Pro + Powerpack?
Currently I'm using MoI 3D + Max Smirnov's ImportObj and Subdivision plug-in commands to convert an all-quad polygon model to a solid, but the downsides to that workflow are:
• It only works properly in the case of relatively low-polygon models, because every quad poly is converted to an individual NURBS patch.
• There is no proper surface continuity when triangular polygons are present in the model.
Regarding the other tools you mentioned: I'm afraid they're both not available for Mac OS.
Metin
Edited by user Monday, November 27, 2017 4:05:20 AM(UTC)  | Reason: Not specified
digitalphaser
#4 Posted : Monday, November 27, 2017 8:07:12 AM(UTC)
digitalphaser
Originally Posted by: Metin Seven Go to Quoted Post
...Is Powerpack Pro also compatible with ViaCAD 2D/3D? If not, what would it cost to upgrade my ViaCAD 2D/3D V9 to the latest ViaCAD Pro + Powerpack?..
I do not know exactly. In my opinion you can find the detailed information here: http://masterviacad.com/store/index.html
It is partly right for PP Pro too. The low- mid-poly models(mostly quads) are best converted to solid. But good mesh up to 1,000,000 quads is also not a problem for PP Pro.
It is the maximum that I tested. But if I do a retopology of complexe model, I try not to exceed 200,000 polygons.
You can see some examples here: http://masterviacad.com/powerpackoverview/styled-50/page35.html
digitalphaser
#5 Posted : Monday, November 27, 2017 8:40:37 AM(UTC)
digitalphaser
A small experiment.
I took a model with a not very clean topology. Each part is up to 70,000 polygons (mostly quads and bit tries). PP easily cope with this task.
