bbuxton
#1 Posted : Saturday, November 25, 2017 7:11:20 PM(UTC)
bbuxton
Japan
Was thanked: 29 time(s) in 14 post(s)
This is the first time I needed to use Catia v5 format.
The file exports but in this instance the export saved some removed features not the actual part.
https://www.dropbox.com/...eatured%20blade.sfx?dl=0
https://www.dropbox.com/...red%20blade.CATPart?dl=0
L. Banasky
#2 Posted : Sunday, November 26, 2017 4:43:36 AM(UTC)
L. Banasky
Was thanked: 141 time(s) in 100 post(s)
I Exported the .sfx as CatiaV4 and Imported in Inventor, works fine.
Exported as CatiaV5 from Inventor, Imported in Shark10 PC works fine.
Will try to attach as .sfx, but file is large. Will also try Zipx.
If forum doesn't upload Zipx, I will add .zip, just remove it.
https://www.dropbox.com/...0blade.CATP3art.sfx?dl=0
Didn't know I had Dropbox, hope it works for you.
Edited by user Sunday, November 26, 2017 7:20:13 AM(UTC)  | Reason: Not specified
defeatured blade.CATP3art.zipx.zip (14kb) downloaded 4 time(s).
defeatured blade.CAT2part3.CATPart.jpg (115kb) downloaded 5 time(s).
bbuxton
#3 Posted : Sunday, November 26, 2017 7:19:13 AM(UTC)
bbuxton
Japan
Thank you Larry.
Unfortunately your zipx.zip unpacks a 0 byte file.
Mostly my post was to query why the Catia v5 export might produce unexpected results.
Exporting step, then re-importing the file back into SharkCAD allows me to export again as CATpart.
Not ideal for larger more complex files. Hopefully Tim will shed some light on this.
Also my apologies for being a bit unclear in my original post...
The sfx file is actually my working file, which I am trying to send as a v5 CATpart
In doing so I noticed unexpected behavior in that features I had removed got exported but the geometry that was needed was removed from the file.
The difference between the two files I posted is that the sfx file contains the turbine blade and the CATpart contains the strut features I removed. I'm sure this is not how Catia v5 export is supposed to work.
Edited by user Sunday, November 26, 2017 10:06:50 AM(UTC)  | Reason: Not specified
L. Banasky
#4 Posted : Sunday, November 26, 2017 7:26:32 AM(UTC)
L. Banasky
Thanks to you as well, Didn't know that I had Dropbox, just added your file to my
original post, a little late.
