cheitmann
#1 Posted : Tuesday, November 21, 2017 4:11:33 PM(UTC)
cheitmann
I can't seem to find the EPS import in my ViaCAD v10 Pro for Windows. I see AI, and have looked around in different importers, I can't seem to find it.
Jolyon
#2 Posted : Tuesday, November 21, 2017 4:16:10 PM(UTC)
Jolyon
EPS Import is certainly in Shark ... I thought it was in ViaCAD too !?
However, it doesn't appear to work as I expect
ie. it imports what amounts to a screenshot of my vector data, but not my actual vector data
Hopefully Tim has a clever fix brewing !?
L. Banasky
#3 Posted : Tuesday, November 21, 2017 4:33:59 PM(UTC)
L. Banasky
Was thanked: 141 time(s) in 100 post(s)
I'm using SharkCad Pro 10 on the PC, and only have EPS Export, perhaps Import
is a Mac only option.
Jolyon
#4 Posted : Tuesday, November 21, 2017 4:50:59 PM(UTC)
Jolyon
OK - thanks Larry
Hope you're doing well !
I just checked - it's definitely on the Mac ... must be Mac only !?
Either way, it doesn't work properly : (
Cheitmann - have you tried DWG import - that works really well from Illustrator and many others
cheitmann
#5 Posted : Monday, November 27, 2017 4:34:58 PM(UTC)
cheitmann
Hi Jolyon,
It must be a Mac-only option. I did find a work around. I needed to get some vector data out of a PDF and into ViaCAD v10 Pro for Windows. I don't have Adobe Illustrator, but I worked around the problem with Inkscape's PDF import, DXF export.
What are other tips or tricks to get vector data out of PDFs?
Jolyon
#6 Posted : Tuesday, November 28, 2017 3:18:35 AM(UTC)
Jolyon
My understanding was that PDF could contain vector data - so that would be the best solution ... a PDF import that does not flatten data to a screenshot - as it appears to currently. (Some of these imports are a bit misleading to my mind)
Yes - EPS Import only on the Mac, presumably because the Mac uses Postscript in it's display pipeline ?
