tangency to "cut section" perimeters
cutting a solid cylinder with the "cut section" tool yields the vast majority of the time an ellipse, or probably more correctly a perimeter that looks like an ellipse. how do I establish a line tangent to a resulting perimeter that looks like an ellipse and a co-planer circle ??
if there's not currently a way to do it directly, is there a way to extract the major and minor axis from a resulting perimeter that looks like an ellipse??
Art
[email protected]
I did this the other day, scaled ellipses are recognised as splines so I wanted to define the figure as ellipse. Apply a bounding box to the spline, the major and minor axes can be measured from the edges of the box.
1 user thanked murray for this useful post.
Murray-
thanks, very clever!! hadn't thought of a bounding box approach. "of course" it took a few more steps because the ellipse isn't aligned with the current work plane.... fortunately verify also provides max & min principle axis so a box can be constructed to enable replacing the perimeter that looks like an ellipse with a real ellipse. convoluted, but it gets there.....
Art
[email protected]
Thanks: 211 times Was thanked: 150 time(s) in 95 post(s)
Originally Posted by: Art Smith if there's not currently a way to do it directly, is there a way to extract the major and minor axis from a resulting perimeter that looks like an ellipse??
[email protected] Hello Art,
I'm sorry to say : a scaled ellipse is not an ellipse any more.
And it's been like this since the time of Pythagorus, or maybe earlier...
I know because I did this mistake before.
Try other ways...
JL
JL-
yes, but it's plenty good enough for estimating "clearance" center lines routing tubes.... it was a CAD mechanization question, not geometry.
Art
[email protected] Art Smith attached the following image(s):
(42kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Art Smith yes, but it's plenty good enough for estimating "clearance" center lines routing tubes.... it was a CAD mechanization question, not geometry.
I understand now.
Great routing job Art !
JL
JL-
thanks! the postulated structural tubes had a huge impact on the degree of difficulty and the quality of the eventual solution. the triangular tubes pushed the exhaust aft AND pushed the point of maximum frontal area aft. without the structure "in the way", normally tube #3 defines maximum width. frontal area and taper ratio are really BIG deals in everything that influences aero drag......
Art
[email protected]
