Import/Export
Illustrator 9+ Imports as 'Picture'
Hi (I’m trialing Affinity Designer) Both Illustrator and Designer import a PDF as a picture - is this right ? [Illustrator saved in a legacy format (v8) works fine as ever] However when saved in a recent (PDF based?) format … and imported using the Illustrator 9+ option … only seems to come through as a ‘Picture' Same with Designer (saved out as a PDF) What am I doing wrong ? Thanks Jol
OK - EPS export from Illustrator or Designer should give me lines and splines I can use in 3D However, it just flattens the data into a 'Picture' Illustrator 9+ Import also does this ... which is wrong to my mind ! If I'm importing data from Illustrator 9+, I want to use that Illustrator data - not just see a 'Picture' of it ! (Importing data via Illustrator v8 or via DWG works fine of course) Can we get vectors transferred via EPS ? Can we label Illustrator 9 Import with ... 'Imports as flattened Picture' - so people can understand what it does
It's my understanding that PDF can carry vector lines and splines Why can't I import lines and splines in a PDF file ... again, it gets flattened to a 'Picture'
Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
I've had the same problem with Illustrator 9. Illustrator 8 usually works but is very slow importing. I usually export from Illustrator as DXF, using the latest option available. This will bring the vector info in to Shark. Nick
Thanks: 15 times Was thanked: 31 time(s) in 27 post(s)
I agree it would be nice to import vectors from pdf files. I usually save as Illustrator 3 and import that. But other vector illustration programs don’t export in ai format and I would love to loose Illustrator. Claus
Import/Export
