This reminds me of AutoCAD in years gone by - when every view rotate was in the undo stack If (navigator) view rotate was the last thing you did ... ... then CTRL-Z (undo) will undo that view rotation Why is view rotate in the undo stack now ? I'm sure it shouldn't be ! Is anyone else seeing this ?
Thanks: 233 times Was thanked: 184 time(s) in 111 post(s)
Originally Posted by: Jolyon Is anyone else seeing this ?
Jol, I'm not seing that...
Hmmm ... might be very specific set of circumstances - I don't care how old I am. If i see a bubble, I will hunt it down and kill it !
OK - I think I have it I use an external trackpad - and I use the Navigator widget for view rotations 3 fingers dragged across the trackpad on the Navigator widget gives me my new view rotation However, if within a half second (or less) of my rotate, I immediately CTRL-Z ... then I get a screen flash - to the previous view rotate state ... and back again So - it's just graphics messy - It's not actually a view problem, pre-se Anyone repeat ? (my shade options are Phong, Phong and Phong) Jol
Jol, does it say the name of the last operation in the Edit : Undo menu? Tim
https://www.dropbox.com/...rf/Untitled%201.mov?dl=0 Here is a movie to show
When using the navigator to view your model ... and then instantly CTRL-Z undoing your previous command
... screen jumps
and a construction line is drawn
(I was wondering why I had so many damn construction lines on my models)
In this short movie - 11 construction lines are drawn on top of one another
