Art Smith
#1 Posted : Wednesday, October 11, 2017 12:19:05 PM(UTC)
Art Smith
does SharkCAD Pro have the functionality to create an "assembly balloon" drawing and bill of material (BOM) ?? a solid model has been created and there's nothing to parsing each of the tubes to a separate layer. see attached illustration
SharkCAD Pro's "User Guide" currently is shown in Italian. how do I change it to English(gringo)??
Art
artesmith@earthlink.net
assembly balloon drawing BOM question.jpg (50kb) downloaded 23 time(s).
#2 Posted : Thursday, October 12, 2017 7:21:22 AM(UTC)
Was thanked: 67 time(s) in 65 post(s)
Hello Art
In the menu Windows is the attribute and BOM. This will allow you to add a BOM table and also add automatic balloons with numbers. There is no automated tool so you would need to create a view and then apply the BOM and Attributes tool to build your drawing you need.
One way to do this and there are many ways depending on the outcome you are looking for.
create New layer
Create a new single draw view (look at drop down in the top and use draw view and not layer view
copy all the geometry
paste it in the draw view - use a solid option flat phong etc.
set the view how you want - isometric, rotated etc.keep as a solid and scale 1:1
flatten draw view - now you are left with a copy of the geometry in the view orientation you want
then select all the objects in the draw view and use the attributes and BOM tool , hit apply to selected
pick bom table from pre-defined drop down or you can add add your own to be available in the drop down
click add balloons, might need to move each around a little or adjust position
and might want to rename the parts this is not easy and one of the downfalls of making a copy of the geometry
there is a update bom so that for example name changes will update
you can then drag a new title block in from the symbols to complete the drawing
Windows 10, Win 7
Elektroniker on 10/12/2017(UTC)
Art Smith
#3 Posted : Thursday, October 12, 2017 11:59:01 AM(UTC)
Art Smith
Jason-
thanks, someplace to start after the user manual challenge is solved. how do I gain access to an English (gringo) version?? I've never used the BOM functionality and as a minimum will need to find it..... does the BOM functionality require each of the objects to be on their own sub-layer or will it also work from with an "assembly" layer??
Art
SharkCAD Pro user manual challenge.JPG (20kb) downloaded 2 time(s).
#4 Posted : Friday, October 13, 2017 6:30:10 AM(UTC)
Was thanked: 10 time(s) in 9 post(s)
The Latest Build of Shark Cad Pro 10 is 1354 and have a english Documentation. Save it at another Place from the Path: "C:\Program Files\Punch! Software\SharkCAD Pro 10\Help\sfx User Guide.pdf" You can Download it if you browse the Download Path to Demo/sharkfx10/SharkCADPro10_1354_WIP.exe (SharkCADPro10_1354_WIP.dmg for Mac)
The Demo Download Archive are open for Browsing and the Demo Versions are no Demo, it are Full Beta Versions or Full Versions.
The BOM seems to be very much in development. I was using this, and it is not able to see the right lenght of a part. Many Handwork is needed.
Edited by user Friday, October 13, 2017 6:38:57 AM(UTC)  | Reason: Not specified
