#1 Posted : Tuesday, October 03, 2017 7:20:35 AM(UTC)
Was thanked: 9 time(s) in 8 post(s)
When export a scaled draw view, the geomenty will be exported completely wrong. The scaled size = 1:1 size. Thats not good. Therefore i trying to use 1:1 Draw Views and make the scale for printing with the Page Layout. But if i use the Text size 9 Pixel by a scale 0,3, the text will be printed not 9 Pixel,it will be printed very much smaller and arrow size of dimensions also to small. Shark should be able to calculate always the correct pixel size for printing for Draw view scale and Page Layout Scale. At time it works only for Draw view scale and not for Page Layout Scale.
#2 Posted : Tuesday, October 03, 2017 8:35:07 AM(UTC)
Was thanked: 67 time(s) in 65 post(s)
Hello
Did you try using a real value like .25" or 2 mm instead of font point sizes? When you print is the preserve annotation sizes checked or unchecked?
Windows 10, Win 7
#3 Posted : Tuesday, October 03, 2017 8:55:45 AM(UTC)
I use for my dimensions always 9 pts (Pixel Points) and i don't use "preserve annotation sizes" because this works also not right and only when changing the scale. If the scale still the same, "preserve annotation sizes" have no effect. The size of a pixel should be always the same when printing i guess this are ca. 0,3mm.
I guess i go back to the scaled draw views, but for export to dxf i need then extra draw views, and when creating a "New Draw View" it can't remember settings.
Edited by user Tuesday, October 03, 2017 9:09:00 AM(UTC)  | Reason: Not specified
