New Topic Post Reply
Claus
#1 Posted : Wednesday, September 27, 2017 12:32:32 AM(UTC)
Quote
Claus
Was thanked: 14 time(s) in 12 post(s)
Tim, there is an old post about SharkCad Pro not being compatible with the latest operating system for macs. Can you update me on this? Maybe the latest beta will run?
thanks, Claus
posh.de
#2 Posted : Wednesday, September 27, 2017 6:19:05 AM(UTC)
Quote
posh.de
don't upgrade to 'High Sierra' beforce checking compatibility of all of your used applications... at least in a professional usage case:
https://www.heise.de/mac...-vor-Update-3840580.html
POSH GmbH
www.posh.de
#3 Posted : Wednesday, September 27, 2017 2:37:46 PM(UTC)
Quote
Was thanked: 170 time(s) in 150 post(s)
Hi Claus
Yes the Work In Progress download from punchcadlab.com runs on High Sierra. Once Encore's QA team reviews/approves it will be placed in the Current Version menu.
ViaCAD/Shark Development Team
EvoSoft
Links to ViaCAD Resources
maggi_magnum
#4 Posted : Wednesday, September 27, 2017 2:38:08 PM(UTC)
Quote
maggi_magnum
Same problem here, har upgrade to "Hig Sierra" and my ViaCad pro 10 stop working. AAAARRRRGGGG!!
#5 Posted : Wednesday, September 27, 2017 2:49:14 PM(UTC)
Quote
See this:
http://forum.punchcad.com/default.aspx?g=posts&t=8919#post33568
If you need something asap until tech support is contacted, download the VaiCAD Pro beta. It was updated to support 10.13.
http://www.punchcadlabs.com/page7/page7.php
EvoSoft
maggi_magnum on 10/1/2017(UTC)
#6 Posted : Thursday, September 28, 2017 8:11:52 AM(UTC)
Attach Quote
Tim,
before the upgrade I was able to open a 53 mb iges file (with some patience). After installing high sierra I just get a spinning wheel. It's remarkable that in Rhino I'm able to open the same file in 5 seconds before and after the upgrade.
Claus
#7 Posted : Thursday, September 28, 2017 10:34:29 AM(UTC)
Quote
Hi Claus
Try turning off the Auto Heal Bodies option, this is very time consuming.
EvoSoft
defkon
#8 Posted : Thursday, September 28, 2017 1:48:51 PM(UTC)
Quote
defkon
Hi Tim,
The same for ViaCad Pro and High Sierra?
Matthias
#9 Posted : Thursday, September 28, 2017 2:40:43 PM(UTC)
Attach Quote
Think I might hold off a little while as I have a project on
If you're not sure - perhaps wait 'til both the OS and the app has been tested further
Be good to hear other's experiences
- for some odd reason I still get excited about updating my Mac : )
#10 Posted : Thursday, September 28, 2017 2:59:44 PM(UTC)
Attach Quote
I'm on High Sierra just now, and it's pretty damn nice on a 2013 i7 iMac. :P Shark falls over, but not using a 10 build.
Tried ViaCAD 10 Beta.. build image is too old today, so must download another to test!
I can always use Fusion 360 in the meantime... ;)
#11 Posted : Friday, September 29, 2017 12:22:36 PM(UTC)
Quote
I just downloaded the ViaCAD Pro 10 Mac beta and tested aok. It is does not expire until Oct 25.
EvoSoft
#12 Posted : Saturday, September 30, 2017 12:28:34 AM(UTC)
Attach Quote
Yes, the beta works fine for me too just using the toolset I was using before. I will keep testing thanks.
24c
#13 Posted : Saturday, September 30, 2017 1:17:00 AM(UTC)
Quote
24c
Hi
I don't think this is restricted to macOS High Sierra, but when using the Push/Pull tool the dialog entry box disappears, so I can't see how far it has moved or edit this easily.
I can edit the value in Concept Explorer, and see the values increasing as I drag the surface, but when I release the mouse the box with the amount moved disappears BUT not always... sometimes it works fine after a multiple Undo.
Using a trackpad, batteries OK.
Odd one
Mike
mac0S 10.13 VCP Beta 1353
Claus
#14 Posted : Saturday, September 30, 2017 6:12:59 AM(UTC)
Quote
Claus
Hi Claus
You’re right, I drag-dropped the file on the current open window to import, apparently it applies the auto heal option. Without auto heal it imported in about a minute.
Claus
Quick Reply Show Quick Reply
You can post new topics in this forum.
You can reply to topics in this forum.
You can delete your posts in this forum.
You can edit your posts in this forum.
You can vote in polls in this forum.
