#1 Posted : Wednesday, September 27, 2017 8:09:35 AM(UTC)
So I bought the tips and tricks booklet today and have been having a scan through it, it's pretty good well done. I have a question though. Importing ply format. I cannot get this to work. There isn't an example ply format file to try either. The booklet says import ply (pretty much) with the words range_grid.
My issue is I have a little scanner which gives me a ply file which is all nonsense when you open it in text. I can convert this to figures using the likes of cloudcompare, but how the hell do I get it to work inside ViaCAD Pro V10?
I've attached a very rubbish scan just as an example. I've tried converting it to text and adding range_grid to the first line, tried running it with no space, spaces, tab spaces, nothing appears when I import it.
Please any help would be great? Even if I know how the file should look when you open it in text editor I could probably get it to work.
Edited by user Wednesday, September 27, 2017 8:10:46 AM(UTC)  | Reason: Not specified
NOTHING.zip (89kb) downloaded 9 time(s).
L. Banasky
#2 Posted : Wednesday, September 27, 2017 10:00:37 AM(UTC)
L. Banasky
Was thanked: 158 time(s) in 108 post(s)
You can import into Blender, which I did, but from there I'm lost as far as exporting
as a file to be used in ViaCad.
Blender is on my computer, but only used by my grandson. When he visits I'll have him try your file.
#3 Posted : Wednesday, September 27, 2017 11:13:49 AM(UTC)
Cool thanks. Yeah I'm wondering if it's like the spline files, you can make them up by adding a //whatever at the start of the file then save as .spl
#4 Posted : Wednesday, September 27, 2017 11:22:58 AM(UTC)
Hello UG
The example you posted is in binary format ply where ViaCAD imports ascii polygon format ply files. Can you specify ascii format from your scanner?
#5 Posted : Wednesday, September 27, 2017 12:08:39 PM(UTC)
I can't but I can stick that file through meshlab/cloudcompare software and get an ascii format, which I've done and that had no affect on importing it, which is what's making me think I need to do something else to the file?
#6 Posted : Wednesday, September 27, 2017 2:29:16 PM(UTC)
I thought we supported Ply binary, will need to debug the file when we get the service packs out.
