macnavi
#1 Posted : Tuesday, September 26, 2017 12:34:13 AM(UTC)
macnavi
Netherlands
After creating a 2-Point Arc, you can adjust the Start angle in Inspector->Data, but not the End angle. If you change the number or make a calculation in the input field, the result is a random number. Never what you told it to.
It seems to work correct with all the other arcs.
Using ViaCad 2d/3D build 1341
Mac OS X El Capitan 10.12.5 - VC 2D/3D v10
BillB
#2 Posted : Tuesday, September 26, 2017 5:27:53 AM(UTC)
BillB
All the arc tools have radius, start angle and total angle input boxes.
Bill Bedford
Viacad Pro 10 (1354)
OS X 10.13.1
macnavi
#3 Posted : Tuesday, September 26, 2017 5:30:12 AM(UTC)
macnavi
Netherlands
Yes they have, but with the 2-point Arc tool, the End angle input box doesn't do what you tell it to.
BillB
#4 Posted : Wednesday, September 27, 2017 12:39:04 AM(UTC)
BillB
It works for me, perhaps you should tell us what numbers you are trying to use.
Edited by user Wednesday, September 27, 2017 12:39:55 AM(UTC)  | Reason: typos
Bill Bedford
OS X 10.13.1
