Linear duplicate negative value for row spacing have no effect
Thanks: 351 times Was thanked: 257 time(s) in 169 post(s)
A negative and a positive value for row spacing have the same effect - only positive. But when the Column spacing negative, the row spacing is then also negative also when a positive number in the field.
Edited by user Monday, September 18, 2017 5:40:45 AM(UTC)
(4kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
