qwertymandarin
#1 Posted : Saturday, September 16, 2017 8:12:00 AM(UTC)
qwertymandarin
When I make any cone primitive and after I enter a new Z position, the cone base radius changes (but not cone height) proportionally to the Z position. When I change Z position of a cylinder also for example, the size changes proportionally but the proportions stay the same. This is all unexpected behaviour to me. Is it a bug or how can I translate a primitive in Z axis parametrically without changing size or proportions?
Edited by user Saturday, September 16, 2017 3:16:43 PM(UTC)  | Reason: Not specified
Primitives that resize by entering Z position.vc3 (17kb) downloaded 4 time(s).
qwertymandarin attached the following image(s):
Cone change.png (170kb) downloaded 11 time(s).
horst.w
#2 Posted : Saturday, September 16, 2017 2:30:54 PM(UTC)
horst.w
Was thanked: 13 time(s) in 11 post(s)
You are changing the value of "Z", use the value of "Height".
When I change the Z-Value, the cone changes its position too, but only up to the new Z-Value without changing its dimensions.
Regars
horst.w, GER
ViaCAD 9 Pro german + ViaCAD 10 Pro & PowerPack
qwertymandarin
#3 Posted : Saturday, September 16, 2017 3:15:58 PM(UTC)
qwertymandarin
Thank you for the reply Horst.
I actually just want to set the position without changing the height or the size in any direction, but the problem is it does on my end. So I want it to work exactly how you are describing it does, so it is good to know that the program does have a bug on my system. I have V10 build 1341 installed, but I guess it could also be an incompatibility with my Windows 10 Home environment.
Edited by user Saturday, September 16, 2017 3:18:54 PM(UTC)  | Reason: Not specified
horst.w
#4 Posted : Sunday, September 17, 2017 12:35:28 PM(UTC)
horst.w
I also have running V10 / 1341, but on a Win 7 Prof.
Diameter and Height determine the dimensions of the cone,
started on Origin (X/Y/Z = 0) the movement of the centerpoint of the cone has reactions as expected.
H.
