Cone changing shape when translated. Bug?
When I make any cone primitive and after I enter a new Z position, the cone base radius changes (but not cone height) proportionally to the Z position. When I change Z position of a cylinder also for example, the size changes proportionally but the proportions stay the same. This is all unexpected behaviour to me. Is it a bug or how can I translate a primitive in Z axis parametrically without changing size or proportions?
Edited by user Saturday, September 16, 2017 3:16:43 PM(UTC)
Primitives that resize by entering Z position.vc3
(17kb) downloaded 4 time(s). qwertymandarin attached the following image(s):
(170kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
You are changing the value of "Z", use the value of "Height". When I change the Z-Value, the cone changes its position too, but only up to the new Z-Value without changing its dimensions. Regars horst.w, GER
Thank you for the reply Horst.
Originally Posted by: horst.w When I change the Z-Value, the cone changes its position too, but only up to the new Z-Value without changing its dimensions
I actually just want to set the position without changing the height or the size in any direction, but the problem is it does on my end. So I want it to work exactly how you are describing it does, so it is good to know that the program does have a bug on my system. I have V10 build 1341 installed, but I guess it could also be an incompatibility with my Windows 10 Home environment.
Edited by user Saturday, September 16, 2017 3:18:54 PM(UTC)
I also have running V10 / 1341, but on a Win 7 Prof. Diameter and Height determine the dimensions of the cone, started on Origin (X/Y/Z = 0) the movement of the centerpoint of the cone has reactions as expected. Regards H.
