#1 Posted : Saturday, September 9, 2017 5:52:44 PM(UTC)
I have been successfully running ViaCAD 2D/3D Pro 8 on my Mac with OS X 10.13, and just installed v10. V10 either never opens, or immediately crashes once it opens. Why won't this run?
Without pasting the entire error report, this is the part that looked somewhat important ("Exceptions" towards bottom):
Process: ViaCAD 2D3D 10 [793]
Path: /Applications/ViaCAD 2D3D 10.app/Contents/MacOS/ViaCAD 2D3D 10
Identifier: com.encore.viacad2D3Dv10esd
Version: 10.0.0 (1316)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: ViaCAD 2D3D 10 [793]
User ID: 503
Date/Time: 2017-09-09 16:49:49.404 -0700
OS Version: Mac OS X 10.13 (17A360a)
Report Version: 12
Anonymous UUID: 426B9733-0051-DEF3-2D64-224B7E10B748
Time Awake Since Boot: 610 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00007ffeef3ffe30
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
#2 Posted : Saturday, September 9, 2017 9:44:13 PM(UTC)
Because Apple has changed the way the OS behaves in 10.13 that is not compatible with ViaCAD or Shark, specifically some of the event handling processing.
We've made some changes to event handling in the current beta build should work on 10.13. A service pack is coming out shortly for all V10 products.
Edited by user Saturday, September 9, 2017 10:25:33 PM(UTC)  | Reason: Not specified
jgdeschamps
#3 Posted : Wednesday, September 27, 2017 12:05:22 PM(UTC)
jgdeschamps
Any news regarding a release date for the service pack? I cannot use ViaCAD under macOS High Sierra...
#4 Posted : Wednesday, September 27, 2017 2:20:38 PM(UTC)
Yes, Encore just released the service pack which also now supports 10.13. See this post.
http://forum.punchcad.com/default.aspx?g=posts&t=8919#post33568
jgdeschamps
#5 Posted : Wednesday, September 27, 2017 2:40:58 PM(UTC)
jgdeschamps
Thank you, I appreciate the quick response. I already used the support request form you posted. Best regards...
vojins
#6 Posted : Saturday, January 6, 2018 4:14:55 AM(UTC)
vojins
Version 9 and older ARE NOT compatible with High Sierra nor will they be updated to support High Sierra. - Not much professional. Whether at least I can get a discount for buying version 10
viabry
#7 Posted : Monday, March 25, 2019 10:09:01 PM(UTC)
viabry
So yeah, I just got ViaCad 2D/3D v.10. Running Mac 10.14.3 Mojave,
ViaCad CRASHES on launch EVERY SINGLE TIME!!
Is there a fix?
MaiFy
#8 Posted : Tuesday, March 26, 2019 2:13:55 PM(UTC)
MaiFy
Hi Viabry
Try calling Todd
Help Page
