Suggestions
View - Hidden with dimmed works not properly
Thanks: 264 times Was thanked: 130 time(s) in 100 post(s)
Very often are hidden lines not dimmed and visible lines are dimmed. This view-mode works completely wrong.
Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
Yes the MTS mode is completely bugged. :(((((
Originally Posted by: MPSchmied Very often are hidden lines not dimmed and visible lines are dimmed. This view-mode works completely wrong.
Can you post some screenshots of this occuring? Is there a particular set of objects that this can be reproduced with?
Originally Posted by: Antoine Yes the MTS mode is completely bugged. :(((((
No, this what i mean have nothing to do with the Model to Sheet.
Originally Posted by: jdi000 Can you post some screenshots of this occuring?
Yes
Update: It seems when only one part, only one solid, at display it works good. But if different solids together at display the hidden parts are shown as visible parts.
Edited by user Tuesday, August 22, 2017 10:14:33 AM(UTC)
(99kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Also the Hidden View and in a bigger distance the Phong View works not properly when a thin sheet covering some construction.The covered construction shining through. Thats really not good.
Suggestions
