#1 Posted : Tuesday, August 22, 2017 6:39:04 AM(UTC)
Very often are hidden lines not dimmed and visible lines are dimmed. This view-mode works completely wrong.
Antoine
#2 Posted : Tuesday, August 22, 2017 8:55:01 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
Yes the MTS mode is completely bugged.
#3 Posted : Tuesday, August 22, 2017 9:05:49 AM(UTC)
Can you post some screenshots of this occuring? Is there a particular set of objects that this can be reproduced with?
#4 Posted : Tuesday, August 22, 2017 9:58:38 AM(UTC)
No, this what i mean have nothing to do with the Model to Sheet.
Yes
Update: It seems when only one part, only one solid, at display it works good. But if different solids together at display the hidden parts are shown as visible parts.
Edited by user Tuesday, August 22, 2017 10:14:33 AM(UTC)  | Reason: Not specified
#5 Posted : Tuesday, September 19, 2017 10:58:17 AM(UTC)
Also the Hidden View and in a bigger distance the Phong View works not properly when a thin sheet covering some construction.The covered construction shining through. Thats really not good.
