Suggestions
Alert message when a user trying to use the c-key or Shift+c for a user defined short cut
Thanks: 279 times Was thanked: 138 time(s) in 106 post(s)
The c-Key and Shift+c are used for the easy changing of the work plane. Therefore it should be forbiddn to use it as a user defined shortcut. This feature should be implemented in the Short-cuts setup so that when the user attemting to use the c-key for another tool, he get a message that it used by easy changing work plane.
Edited by user Wednesday, August 23, 2017 3:20:52 AM(UTC)
Thanks: 43 times Was thanked: 42 time(s) in 29 post(s)
Yes, I think I understand what you are trying to say
I deleted that short cut before appreciating its value in 3d modeling mode.
I tried to restore it to factory defaults in the short cut manager, then save it as new key set a while ago without success.
I couldn't find the category or command in short cut manager to get it working again.
I was wondering also if anyone else knew how to do it.
Zircon laid out all the commands and shortcuts in a post a while ago,
Zircons list of shortcuts I went through a few of them but was unable to locate it.
Any help appreciated.
Edited by user Tuesday, August 22, 2017 11:46:15 PM(UTC)
| Reason: Wrong Picture
(39kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Suggestions
