3D mode does not work correctly with DIM/TEXT tools
Please fix this error. ALL, but 2 tools, do not work correctly or at all in 3D mode in my ViaCAD Pro v10 program. Today is August, 18th, 2017. The 2 tools that do work correctly in 3D mode that are dimension and text tools are: Horizontal Text and Length Dimension (along a curve). NOTE: ALL dimension and text tools DO WORK in 2D mode correctly however. Please fix this via future patches beyond 1341 for ViaCAD Pro version 10. -Kevin Eidsmore @Eidsmore on Twitter P.S. I also posted in one other place: 'suggestions'
Thanks: 351 times Was thanked: 257 time(s) in 169 post(s)
When you set a 3 Pts Work Plane this both tools works good in 3D. But i also will be happy if this fixed (made full 3D) sometimes.
Edited by user Saturday, August 19, 2017 5:18:05 AM(UTC)
Originally Posted by: Kevin Eidsmore Please fix this error. ALL, but 2 tools, do not work correctly or at all in 3D mode in my ViaCAD Pro v10 program. Today is August, 18th, 2017. The 2 tools that do work correctly in 3D mode that are dimension and text tools are: Horizontal Text and Length Dimension (along a curve). NOTE: ALL dimension and text tools DO WORK in 2D mode correctly however. Please fix this via future patches beyond 1341 for ViaCAD Pro version 10. -Kevin Eidsmore @Eidsmore on Twitter P.S. I also posted in one other place: 'suggestions'
Kevin
You need to have the correct plane selected to place the dimensions / text on.
