thmrtnz
#1 Posted : Sunday, August 20, 2017 12:52:26 PM(UTC)
thmrtnz
Hello,
ViaCAD 1341 / macOS 10.12.6 ;
Setting up a print job with 2 draw views produces this bizarre result, despite all the fonts being used for dimensions being installed and activated on the computer.
Is this a known bug, are there reliable workarounds?
Thank you,
Regards,
thmrtnz
UserPostedImage
Untitled 1.pdf (174kb) downloaded 10 time(s).
thmrtnz
#2 Posted : Sunday, August 20, 2017 3:37:20 PM(UTC)
thmrtnz
I have found that there is a low resolution picture embedded inside the pdf, see attached files.
Is this regular? Do I need to clean the document with a vector editing tool? Is it an issue with Apple PDF engine?
Regards,
thmrtnz
Screen Shot 2017-08-20 at 23.33.40.png (1,362kb) downloaded 10 time(s).
Screen Shot 2017-08-20 at 23.33.47.png (1,325kb) downloaded 6 time(s).
Screen Shot 2017-08-20 at 23.34.15.png (1,311kb) downloaded 8 time(s).
#3 Posted : Monday, August 21, 2017 8:16:35 AM(UTC)
thmrtnz
Can you post that ViaCAD file?
thmrtnz
#4 Posted : Monday, August 21, 2017 11:52:49 AM(UTC)
thmrtnz
Hello Jason,
Sure, see attached file.
Thank you,
thmrtnz
Untitled 1.vcp (345kb) downloaded 14 time(s).
#5 Posted : Monday, August 21, 2017 12:03:48 PM(UTC)
Here is pdf printed from ViaCAD to cutepdf print driver on Windows 10 system.
ViaCAD Pro _Untitled 1.pdf (17kb) downloaded 15 time(s).
thmrtnz on 8/21/2017(UTC)
thmrtnz
#6 Posted : Monday, August 21, 2017 12:21:48 PM(UTC)
thmrtnz
Thank you. There must be a problem with my Apple pdf printer.
BillB
#7 Posted : Tuesday, August 22, 2017 2:06:16 AM(UTC)
BillB
It works OK with my OS 12.6
Untitled%201.pdf (84kb) downloaded 15 time(s).
Bill Bedford
Viacad Pro 11 (11417)
OS X 10.13.6
thmrtnz
#8 Posted : Tuesday, August 22, 2017 2:41:18 AM(UTC)
thmrtnz
Thank you. Definitively something is wrong here. I'll fix it!
thmrtnz
#9 Posted : Tuesday, August 22, 2017 5:52:37 PM(UTC)
thmrtnz
Well, I have reinstalled macOS and I still get this result. I don't get it.
thmrtnz
#10 Posted : Wednesday, August 23, 2017 1:56:11 AM(UTC)
thmrtnz
Hello,
Using another CAD package, I get perfect results. I'm puzzled.
BillB
#11 Posted : Wednesday, August 23, 2017 2:52:51 AM(UTC)
BillB
There are two copies of your drawings in your ViaCAD file. Preview shows these as pages 1 and 3 of the pdf I made. Whatever you are using to view the pdf is overlaying the two versions of the draw.
Bill Bedford
OS X 10.13.6
thmrtnz
#12 Posted : Wednesday, August 23, 2017 5:21:17 AM(UTC)
thmrtnz
I understand it works quite right with the right type view selected in Properties panel of a given Layer View.
Here are two files attached to explain.
add.: and here is the extracted background, from Phong type view.
Edited by user Wednesday, August 23, 2017 7:41:04 AM(UTC)  | Reason: Not specified
copy.pdf (162kb) downloaded 7 time(s).
copy.vcp (50kb) downloaded 5 time(s).
thmrtnz attached the following image(s):
copy background.jpg (57kb) downloaded 4 time(s).
BillB
#13 Posted : Thursday, August 24, 2017 2:29:27 AM(UTC)
BillB
This is a screen shot of the page layout of your file using A1 paper
PastedGraphic-1.pdf (113kb) downloaded 7 time(s).
Bill Bedford
OS X 10.13.6
thmrtnz
#14 Posted : Thursday, August 24, 2017 2:59:53 AM(UTC)
thmrtnz
Thank you.
I know there are three sheets but it is not related to my corrupted output. If I define the Page layout to print cleanly only one sheet, and the Layer View is still phong type rendering, there's a bitmap/raster background. I have clean install a second time macOS Sierra 10.12.6 and the issue persist. Ah, I don't get it.
Guest (10)
