#1 Posted : Friday, August 18, 2017 7:05:25 AM(UTC)
So I'm trying to rotate a part around a point which I have set up. The images show the point. I move the gripper to the point by selecting USER POSITIONED from the 'Attach' drop down. I then select the part to rotate and swing it round as I please using the gripper. That's fine but if I type in an angle to rotate by nothing happens?
Standin Man_Mod Me.jpg (75kb) downloaded 11 time(s).
rotated by hand.jpg (358kb) downloaded 9 time(s).
typed in rotated by 90 part hasn't moved.jpg (356kb) downloaded 10 time(s).
L. Banasky
#2 Posted : Friday, August 18, 2017 12:43:07 PM(UTC)
L. Banasky
Was thanked: 158 time(s) in 108 post(s)
I just tried with a cube and line, set the origin at the midpoint of the line, selected both,
entered an angle, and hit enter, and the cube moved the number of degrees.
Your model is way more complicated than the line and cube. Don't know if this will help.
Edited by user Friday, August 18, 2017 12:45:45 PM(UTC)  | Reason: Set Origin, not Axis
Set Axis.jpg (87kb) downloaded 14 time(s).
#3 Posted : Friday, August 18, 2017 2:17:13 PM(UTC)
Crazy! I've just tried it again and it's worked fine? Maybe it had a breakdown earlier! :-)
