Antoine
#1 Posted : Wednesday, August 16, 2017 7:11:02 AM(UTC)
Antoine
Switzerland
Was thanked: 32 time(s) in 26 post(s)
Hello Tim,
SharkPro v.10 1341
The mts module is always completely bugged.
It has been going on for 10 years now.
Please, solve this, thank you.
Antoine
thanks 1 user thanked Antoine for this useful post.
jlm on 10/31/2017(UTC)
#2 Posted : Thursday, August 17, 2017 12:19:01 AM(UTC)
Originally Posted by: Antoine Go to Quoted Post
Hello Tim,
Antoine
I support Antoine's request.
3D design with Shark is now impressively good.
2D needs care to catch-up...
2D drawings are absolutely necessary before launching an industrial project.
It is the right tool to specify :
- dimension tolerances,
- surface finishes,
- material specifications.
- process instructions for molding, cutting, treating, assembling...
For complex parts there are too many MTS flaws :
- ACIS errors,
- precise curves bugs,
- bad view displays (missing curves),
- dimensions and text bad behaviors,
- sections not working with coincident surfaces,
- irregular hatches,
- page format, fonts and layouts changing after re-opening,
- imperial inches popping in sometimes...
I call a complex part any Nurb model with threads, draft, blends & heavy history...
JL
#3 Posted : Thursday, August 17, 2017 4:55:51 AM(UTC)
Was thanked: 253 time(s) in 167 post(s)
#4 Posted : Thursday, August 17, 2017 5:47:08 AM(UTC)
MTS = Model To Sheet = 2D module of Shark
#5 Posted : Thursday, August 24, 2017 7:16:37 AM(UTC)
Am I the only one to get this ACIS error every time I di a Model to sheet with precise curves ?
Best regards,
JL
Capture d’écran 2017-08-23 à 15.11.42.png (191kb) downloaded 4 time(s).
Capture d’écran 2017-08-23 à 15.13.39.png (89kb) downloaded 4 time(s).
#6 Posted : Friday, October 27, 2017 3:28:24 AM(UTC)
Hello Tim,
Antoine
- surface finishes,
- ACIS errors,
JL
Still the same on b1355
GARLIC on 10/27/2017(UTC)
Antoine
#7 Posted : Tuesday, October 31, 2017 4:47:11 AM(UTC)
Antoine
Switzerland
+1
it's been 10 years that I ask to regularize these old bug and optimization.
Antoine
#8 Posted : Tuesday, October 31, 2017 6:15:28 AM(UTC)
+1
Antoine
Message to Tim :
We have a fantastic 3D tool and a miserable 2D module.
It's getting worse and worse with new bugs coming in every new version.
We just can't trust the software for professional use.
I always make the MTS work on a saved-as copy, and print pdf as soon as possible because there are great chances that my file is totally messed-up the next time I re-open it :
- line style changing to mysterious "Hid"
- hatches invading space, or disappearing
- text turning to "Hebrew"
- inches coming around in my metric word
- page layouts prefs back to imperial
- precise curves totally buggy
- dimensions changing color
- detail views dumb hatches
- LINKS WITH SOLID NOT OPERATING (most of the time a solid modification is not updated in the drawing)
- ACIS errors.
Capture d’écran 2017-09-28 à 14.53.01.png (151kb) downloaded 5 time(s).
#9 Posted : Tuesday, December 5, 2017 8:40:07 AM(UTC)
Message to Tim :
- ACIS errors.
Capture d’écran 2017-12-05 à 15.35.32.png (122kb) downloaded 1 time(s).
#10 Posted : Thursday, January 4, 2018 8:27:35 AM(UTC)
Even for simple models I get this...
Capture d’écran 2018-01-04 à 15.24.27.png (94kb) downloaded 2 time(s).
#11 Posted : Friday, October 26, 2018 3:01:29 PM(UTC)
Can I reactivate this thread ?
Status after one year :
Yes we had some major bug solved :
- No more ACIS errors EHL22
- Precise curves are now more precise.
- Hatches are clearly better, (though not perfect).
Thanks Tim and Team !
All the other points mentioned are still here...
JL
#12 Posted : Wednesday, March 20, 2019 6:13:02 AM(UTC)
JL
For V11, please...
rockyroad_us
#13 Posted : Friday, March 22, 2019 7:36:29 AM(UTC)
rockyroad_us
Jim, on the simple model you had referenced a year ago, can you share the file. To me, sometimes it is the darn 3D solid model and sometimes that needs to be fixed first. I suppose if another user can verify the claim then it will prudent to say that it is the actual MTS.
#14 Posted : Friday, March 22, 2019 9:39:44 AM(UTC)
Do you mean a reference to this other post ?
http://forums.punchcad.c...sts&t=9571#post36345
The simple file ( MTS3.sfx ) was attached to the post...
rockyroad_us
#15 Posted : Friday, March 22, 2019 4:43:18 PM(UTC)
rockyroad_us
No, I meant the file that you got the jpg from that was in post #10. The one that says process edges error. Not the one with the spheres. That I can confirm.
#16 Posted : Saturday, March 23, 2019 4:27:43 AM(UTC)
Dear Rockyroad,
As mentioned previously the issue of post#10 (EHL22) has been solved thanks to Tim.
JL
