cad'n'stuff
#1 Posted : Sunday, August 13, 2017 9:00:09 AM(UTC)
cad'n'stuff
Was thanked: 47 time(s) in 23 post(s)
Hello there
I just tried to make a SubD cylinder and noticed 2 strange things:
1. If I type in a specific number of rings, it creates a cylinder with 1 ring less than desired. So, if I want a ring with 8 sides, I have to type 9.
2. Using the gripper, I can't rotate the cylinder around its axis. It only rotates the gripper itself. Reseting the gripper didn't help either.
I'm fairly new to viacad, so it could also be a user error, but I guess it's not.
#2 Posted : Sunday, August 13, 2017 4:17:48 PM(UTC)
Corrected in next beta.
I was not able to repeat this. I did notice scaling was not working correctly and update that in the next beta.
Thanks!
cad'n'stuff
#3 Posted : Tuesday, August 15, 2017 1:13:01 PM(UTC)
cad'n'stuff
Ok thanks, at least it wasn?t my fault :-)
For my gripper problem I found a little workaround. Clicking on the cylinder and rotating with the gripper doesn't seem work, but If I select it by drawing a box from right to left, rotating works just fine.
David
