Help - can't start any Punch software (0xc0000142)
Hello, I want to try Shark and ViaCAD Pro V10 trials, but can't start both, because I got error message: Error: "The application was unable to start correctly." (0xc0000142) My system spec Windows 7, 8GB ram, i7 860, Nvidia 960
Thanks: 634 times Was thanked: 103 time(s) in 65 post(s)
Hi mate, try this approach:
first- a bit of reading
http://microsoftonlinech...00142-in-windows-7-8-10/ and run this command, it may help to get your system repaired..
sfc /scannow
good luck
regards
G.
Thanks, but this didn't help. System File Check: ok Direct access, no proxy. I reinstall all vcredist from 2003 to 2017, updated flash, java, graphic drivers etc but can't fix.
Gotcha, I uninstalled the "Adobe Acrobat 9 Pro Extended 64-bit Add-On and both working now!
sometimes it is a good idea to check the Event Viewer:
https://www.sevenforums....pen-use-windows-7-a.html regards
G.
