#1 Posted : Saturday, August 12, 2017 2:32:54 PM(UTC)
Hello,
I want to try Shark and ViaCAD Pro V10 trials, but can't start both, because I got error message:
Error: "The application was unable to start correctly." (0xc0000142)
My system spec Windows 7, 8GB ram, i7 860, Nvidia 960
GARLIC
#2 Posted : Saturday, August 12, 2017 3:48:46 PM(UTC)
GARLIC
Was thanked: 103 time(s) in 65 post(s)
Hi mate, try this approach:
first- a bit of reading
http://microsoftonlinech...00142-in-windows-7-8-10/
and run this command, it may help to get your system repaired..
sfc /scannow
good luck
regards
G.
#3 Posted : Saturday, August 12, 2017 4:38:28 PM(UTC)
Thanks, but this didn't help.
System File Check: ok
Direct access, no proxy.
I reinstall all vcredist from 2003 to 2017, updated flash, java, graphic drivers etc but can't fix.
#4 Posted : Saturday, August 12, 2017 4:49:00 PM(UTC)
Gotcha,
I uninstalled the "Adobe Acrobat 9 Pro Extended 64-bit Add-On and both working now!
GARLIC
#5 Posted : Sunday, August 13, 2017 1:23:01 AM(UTC)
GARLIC
sometimes it is a good idea to check the Event Viewer:
https://www.sevenforums....pen-use-windows-7-a.html
regards
G.
