is there a way to blend (with either standard Shark or Powerpack tool(s)) the overhanging geometry shown in the attached image? failing that, how would one go about imposing the tube profile on the perimeter of the hoop?
thanks
Art
[email protected] Art Smith attached the following image(s):
(29kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Hi Art You could try... 1. Face /Face blend (hold shift key to select each face) 2. Edge blend with retain features enabled. 3. Fixed width blend Tough looking blend! Tim
Tim-
thanks for the blend ideas. couldn't make any of them work. a one rail sweep solid perpendicular to the perimeter curve followed by a blend fillet did the trick............ not eloquent but got the job done!
Art
(32kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked Art Smith for this useful post.
Thanks: 264 times Was thanked: 130 time(s) in 100 post(s)
There is also a Problem with removing the Blending with the tool "Remove Face".
Edited by user Friday, August 11, 2017 10:31:40 AM(UTC)
(7kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Try holding the shift key and selecting the adjacent face blends.
