thefro
#1 Posted : Saturday, August 5, 2017 10:33:35 AM(UTC)
thefro
Hi
I am having a problem using the join curves tool when the curves are in contact with one another two straight lines. If I move the curves slightly apart they join. if they are at a slight angle and in contact they also join. I have followed the instructions to the letter
Am I doing something wrong as I'm sure this worked in the past. and have used the software for a long time
I have created new drawings with only two lines just to test this
I have shark pro v10 with power pack pro.
Brian
#2 Posted : Saturday, August 5, 2017 10:43:16 AM(UTC)
HI Brian
Can you post the file with the two curves?
#3 Posted : Saturday, August 5, 2017 2:28:18 PM(UTC)
Thanks for the example file Brian, this will now be fixed in the next beta upload.
thefro
#4 Posted : Saturday, August 5, 2017 2:29:43 PM(UTC)
thefro
thank you Tim
Brian
