defkon
#1 Posted : Thursday, August 3, 2017 5:03:18 AM(UTC)
defkon
If i import some files in format such as obj, 3ds, sip etc in my VC 10 drawing and want print this
the imported things are not printed.
Anyone a idea?
Matthias
#2 Posted : Thursday, August 3, 2017 5:13:57 AM(UTC)
Hello Matthias
Are you printing a 3d view of objects ? Can you explain what setup you used to print?
defkon
#3 Posted : Thursday, August 3, 2017 10:34:23 AM(UTC)
defkon
Hi Jason,
see the picture, Z1 is with print window Z 2 is with the print menu.
The small table is imported DWG file and the bigger one a 3DS file the cubes
are normal objects.
Using VC 10 build 1341 on Mac OS 10.11
Matthias
defkon attached the following image(s):
Z 1.png (156kb) downloaded 6 time(s).
Z 2.png (127kb) downloaded 6 time(s).
#4 Posted : Thursday, August 3, 2017 10:48:16 AM(UTC)
Matthias,
Is it just these two imported objects? Can you import a different object and it prints? Can you post the files that you imported?
defkon
#5 Posted : Thursday, August 3, 2017 10:56:46 AM(UTC)
defkon
No its not only with these objects, only example.
Here are the files,
cant upload 3ds
Edited by user Thursday, August 3, 2017 10:58:46 AM(UTC)  | Reason: Not specified
Example.vcp (99kb) downloaded 6 time(s).
29080.dxf (658kb) downloaded 4 time(s).
#6 Posted : Thursday, August 3, 2017 11:08:27 AM(UTC)
Repeated here when using wireframe. Checking into....
Update:
Now fixed in the next set of builds (1348+).
Edited by user Thursday, August 3, 2017 3:58:58 PM(UTC)  | Reason: Not specified
