Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
If i import some files in format such as obj, 3ds, sip etc in my VC 10 drawing and want print this the imported things are not printed. Anyone a idea? Thanks Matthias
Hello Matthias Are you printing a 3d view of objects ? Can you explain what setup you used to print? Regards Jason
Hi Jason,
see the picture, Z1 is with print window Z 2 is with the print menu.
The small table is imported DWG file and the bigger one a 3DS file the cubes
are normal objects.
Using VC 10 build 1341 on Mac OS 10.11
Matthias
defkon attached the following image(s):
(127kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Matthias, Is it just these two imported objects? Can you import a different object and it prints? Can you post the files that you imported? Thanks Jason
No its not only with these objects, only example.
Here are the files,
cant upload 3ds
Edited by user Thursday, August 3, 2017 10:58:46 AM(UTC)
Example.vcp
(99kb) downloaded 6 time(s). 29080.dxf
(658kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Repeated here when using wireframe. Checking into....
Update:
Now fixed in the next set of builds (1348+).
Edited by user Thursday, August 3, 2017 3:58:58 PM(UTC)
