I had to rearrange my monitors and display configuration for compatibility reasons. Now none of my toolbars or tool bar flyouts are displayed. Is there way to bring them back to the home area of the VC screen without working backwards through all the display changes I had to do, and then trying to figure out where to put everything so it will show when I change it back again to what I want? A sort of home all tool bars command or method?
>>A sort of home all tool bars command or method? Try Preferences : Factory All. Tim
My toolbars and palettes are totally messed-up when I plug / unplug an external monitor or projector to my MacBook Pro... Sometimes it gets totally blocked with missing palettes (out of the screen)...
Mine did this, no matter how much moving about they kept disappearing, just delete these two files and it sort of 'hard resets' all your setting, toolbars etc. You'll have to go and reposition them, but might stop the frustration :-) C:\Users\USRNAME\AppData\Local\Punch!\ViaCAD Pro VCPDialogs.ini VCPPrefs.ini
Thanks: 233 times Was thanked: 184 time(s) in 111 post(s)
Originally Posted by: UGMENTALCASE Mine did this, no matter how much moving about they kept disappearing, just delete these two files and it sort of 'hard resets' all your setting, toolbars etc. You'll have to go and reposition them, but might stop the frustration :-) C:\Users\USRNAME\AppData\Local\Punch!\ViaCAD Pro VCPDialogs.ini VCPPrefs.ini
I do this frequently.
For Shark it is : SFXDialogs.ini
