clarkwr1
#1 Posted : Thursday, July 20, 2017 7:20:13 AM(UTC)
clarkwr1
How do you draw this arc.
arc 1.vcp (286kb) downloaded 21 time(s).
#2 Posted : Thursday, July 20, 2017 7:38:12 AM(UTC)
Hello
Are you tracing this from a picture or do you have dimensions available?
clarkwr1
#3 Posted : Thursday, July 20, 2017 8:09:05 AM(UTC)
clarkwr1
the dimensions don't really matter. Just draw two circles and try to get the tangent arc to go to the outside as depicted.
L. Banasky
#4 Posted : Thursday, July 20, 2017 12:39:49 PM(UTC)
L. Banasky
I don't really know an easy way in ViaCad. We need to add tan,tan,radius to the circle menu
for our Wish List. AutoCAD has had it for decades.
For your drawing I would trace and scale a known dimension.
I know this video won't help, but shows tan,tan, radius.
http://www.screencast.com/t/UqK0rJWTCYx
Here's a link to a traced arc.
http://www.screencast.com/t/N6Sg6Fpqp8
Edited by user Thursday, July 20, 2017 1:14:32 PM(UTC)  | Reason: Not specified
rokoko
#5 Posted : Thursday, July 20, 2017 1:30:44 PM(UTC)
rokoko
you can try a solution with one guide line and the three tangent circle tool
finally you can trim the resulting circle
Edited by user Thursday, July 20, 2017 1:38:25 PM(UTC)  | Reason: Not specified
threetangentcircle.vcp (278kb) downloaded 12 time(s).
24c
#6 Posted : Friday, July 21, 2017 7:04:35 AM(UTC)
24c
Was thanked: 69 time(s) in 51 post(s)
..or you can use the Tangents Points Arc tool, twice over to do the same.
1. Draw two circles
2. Draw line, at a tangent off one of the circles, or either perpendicular from a radius
3. Use the Tangent arc tool and create an arc that meets virtually at a tangent on the second circle (I'm sure I can set this to snap by altering something in the preferences)
If you're not happy with this, then create a tangent line off the second circle and use the Tangent Points Arc tool to work back to the first one, and it'll be a little closer to a tangential curve.
Admittedly a fudge, and probably not quite precise enough, but it works OK for me.
Screen Shot 2017-07-21 at 13.58.42.png (29kb) downloaded 4 time(s).
macOS Tahoe - v16 beta
