How do you draw this arc.
arc 1.vcp
(286kb) downloaded 21 time(s). You cannot view/download attachments. Try to login or register.
Hello Are you tracing this from a picture or do you have dimensions available? Regards Jason
the dimensions don't really matter. Just draw two circles and try to get the tangent arc to go to the outside as depicted.
Thanks: 181 times Was thanked: 159 time(s) in 109 post(s)
I don't really know an easy way in ViaCad. We need to add tan,tan,radius to the circle menu
for our Wish List. AutoCAD has had it for decades.
For your drawing I would trace and scale a known dimension.
I know this video won't help, but shows tan,tan, radius.
http://www.screencast.com/t/UqK0rJWTCYx Here's a link to a traced arc.
http://www.screencast.com/t/N6Sg6Fpqp8 Larry
Edited by user Thursday, July 20, 2017 1:14:32 PM(UTC)
you can try a solution with one guide line and the three tangent circle tool
finally you can trim the resulting circle
Edited by user Thursday, July 20, 2017 1:38:25 PM(UTC)
threetangentcircle.vcp
(278kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 42 times Was thanked: 69 time(s) in 51 post(s)
..or you can use the Tangents Points Arc tool, twice over to do the same.
1. Draw two circles
2. Draw line, at a tangent off one of the circles, or either perpendicular from a radius
3. Use the Tangent arc tool and create an arc that meets virtually at a tangent on the second circle (I'm sure I can set this to snap by altering something in the preferences)
If you're not happy with this, then create a tangent line off the second circle and use the Tangent Points Arc tool to work back to the first one, and it'll be a little closer to a tangential curve.
Admittedly a fudge, and probably not quite precise enough, but it works OK for me.
(29kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
macOS Sequoia - MacBook M1 Max 64GB 2TB SSD & external display - SharkCAD Pro v14.1.0 build 1654 macOS Tahoe - v16 beta
