Using Image for Background
Afternoon all, Trying to set an image (.jpg, .bmp etc.) as my background but no matter what file format I use, no matter what file size it is, nothing happens? Anyone had any joy with this? Thanks
Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
Did you try IMPORT .jpg?
(58kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hello
Not working on Windows V10 builds, here as well.
Did you submit a bug?
http://www.punchcadlabs.com/page10/page10.php Thanks
Edited by user Tuesday, July 18, 2017 12:29:04 PM(UTC)
| Reason: image
(11kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Not yet but I will do, thanks.
Just curious if I'm missing a useful feature. What advantage does using an image as a Background have over Importing an image? Using an image as a Background works in Ver7, but was not offered as an option in Ver.5 and previous versions, as far as I know. Please offer an example of using an image as a Background. Thanks, Larry
I think sometimes getting a good background colour/image helps a lot. I do a lot of point work, and the graphics can get a little choppy, especially because the points are small. So sometimes being able to swap and change helps bring features clearer. The import jpg option is more for working on the jpeg no? Im talking about having a file, new, and then it opens up with whatever you have chosen
