Hello, i create a 3d part with Viacad 10 2d/3d. Now its not more possible to make boolean operations with the part. I can not marker it. Other operations move, mirror, rotating are possible. Is there a maximum of polygons for boolean operations? Thanks Hans
Was thanked: 180 time(s) in 160 post(s)
Hello Hans Is your part a Mesh or Solid? A Solid has no limits to the number of faces that can be used in a boolean operation. Tim
Hello Tim, many thanks for your answer. What is the diffrence between solid and meshes? If its meshes, can I convert to solid? Hans
Hello Hans
Meshes are collections of 3 or 4 sided facets created from facet tools or importing stl/obj files. Solids are defined by more complex equations (NURBS/Analytics) and used for modeling operations like blending and shelling.
A quick way to tell what you have is to open Concept Explorer : Entities Tab : All Objects : Selected Only (off). Meshes are usually displayed with a green icon while solids use a blue icon.
Edited by user Tuesday, July 04, 2017 1:21:06 PM(UTC)
(168kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Hello Tim, there is a difference in the german version. It shows only the selected items. The item is named "Facettennetz". Hans
Thanks: 3 times Was thanked: 36 time(s) in 32 post(s)
do a right click in a free space in concept explorer to select visible items
(42kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
viacad pro 10 powerpackpro, viacad pro 9 german, mac os 10.8, 10.9
