New Topic Post Reply
#1 Posted : Friday, June 30, 2017 9:21:22 AM(UTC)
Quote
Was thanked: 160 time(s) in 141 post(s)
PowerPack Pro in 1344 now includes testing of a 3D thread feature.
http://www.csi-concepts.com/Demo/videos/thread.mp4
Please use the topic thread to provide feedback.
Thanks!
ViaCAD/Shark Development Team
EvoSoft
Links to ViaCAD Resources
24c
#2 Posted : Friday, June 30, 2017 9:59:30 AM(UTC)
Quote
24c
Hi Tim,
As somebody who has squealed for this some years ago, I was excited to see it making an appearance.
First impressions, when using a metric system, the pitch values don't seem to convert properly, as a M10x1 thread isn't looking like your examples in the video.
I drew a 10mm diameter rod, and applied the thread pitch value of 1 to the dialog box.
Obviously, your thread profile is in early stages, and is 60º based, but I assume maybe there will be a drop down for other thread standards at a later date, and likewise an internal thread function later too.
Thanks for this so far.
Mike
24c
#3 Posted : Friday, June 30, 2017 10:14:20 AM(UTC)
Quote
24c
OK, so I changed my preferences in the 1344 ViaCAD Beta to inches, and I drew the same model, a 10mm diameter cylinder, aka 0.393", with a 0.04 pitch and I get the same result.
Am I doing something wrong :?
Mike
24c
#4 Posted : Friday, June 30, 2017 10:43:46 AM(UTC)
Quote
24c
OK, getting somewhere, same drawing as before, but unchecked right hand helix...
so this is inch versions of the M10x1 equivalent thread
Mike
24c
#5 Posted : Friday, June 30, 2017 10:50:23 AM(UTC)
Quote
24c
Hi Tim,
It appears to be an issue with the Helix direction checkbox, as I have just redrawn a 10mm rod using metric preferences, aka millimetres and the same behaviour with RH helix vs LH helix is cropping up.
Hope this helps
Mike
#6 Posted : Friday, June 30, 2017 10:59:21 AM(UTC)
Quote
Hi MIke
Correcting now....many thanks for the quick feedback!
>> and is 60º based,
Yes, will need to research other forms.
Also not sure what to do about tolerances.
EvoSoft
24c
#7 Posted : Friday, June 30, 2017 1:22:20 PM(UTC)
Quote
24c
>> Correcting now..
Great stuff Tim,
I have a defect yellow engineering book full of them, but these images will help.
My thoughts are you could link these to a drop down in the thread dialog box, and maybe have a pictorial representation in an advanced tab, or in the Inspector, when you click on the thread part in Concept Explorer.
Possibly even have a "custom field", so you can create a bespoke thread.
Possibly have a default thread standard in "Preferences", but allow a custom change.
Mike
PS Re standards... I wouldn't get hung up on this yet, as just having a thread tool that catered for default standards like 6H in Metric ISO/DIN for example would be enough, and in most cases a tweak to the diameter of the "cylinder" would cover the standards range
#8 Posted : Saturday, July 01, 2017 5:29:20 PM(UTC)
Quote
Thanks Mike!
I uploaded new 1345 builds today with some thread corrections.
EvoSoft
24c
#9 Posted : Sunday, July 02, 2017 3:09:03 AM(UTC)
Quote
24c
Hi Tim,
Downloaded and tested 1345 ViaCAD Pro, so far so good.
I even "shelled" a cylinder, and applied an internal thread to it, and it worked great, as it recognised the cylindrical face OK. 8)
Mike
24c
#10 Posted : Sunday, July 02, 2017 4:48:30 AM(UTC)
Quote
24c
Hi again,
Yep, everything is working out OK so far, and it works well.
I found that it takes a little more time to process the hole punching, as the model is more complicated (larger?) with the thread detail, and even more so if you add a internal radius to the thread forms.
I was simulating a thread tool tip cutting profile on a lathed part.
Mike
ps It did fail a "torture test" on the LH fictional part, which I had applied a radius to the thread forms when I tried to flip the thread from RH to LH, but the unadulterated RH part worked fine, and the former rebuilt itself OK afterwards. :)
Edited by user Sunday, July 02, 2017 4:50:50 AM(UTC)  | Reason: Not specified
24c
#11 Posted : Sunday, July 02, 2017 4:59:19 AM(UTC)
Quote
24c
Hi yet again,
I was even able to import or drag a "castellated' nut from TracePartsOnline, and apply a screw thread to the STEP file, which is pretty damn smart and well speeds up my visualisations.
L. Banasky
#12 Posted : Sunday, July 02, 2017 10:08:23 AM(UTC)
Quote
L. Banasky
Was thanked: 32 time(s) in 28 post(s)
Hi Mike,
I'm happy to see threaded options in Shark, thanks Tim.
Mike,if you need threaded parts in STEP format, McMaster has them for free.
https://www.mcmaster.com/#93760a337/=18bo4l3
24c on 7/2/2017(UTC)
thefro
#13 Posted : Monday, July 03, 2017 2:20:01 AM(UTC)
Quote
thefro
Hi Tim
When selecting the thread if the Inspector is open it is not triggering displaying the pitch and length in Object Properties this happens using deep select (Select Deep) and not the select tool.
if I click pen properties or one of the other options then return to Object Properties the information is displayed please see screen shots.
Brian
Edited by user Monday, July 03, 2017 2:35:45 AM(UTC)  | Reason: spell
thefro attached the following image(s):
24c
#14 Posted : Monday, July 03, 2017 2:48:13 AM(UTC)
Quote
24c
Hi Brian,
I am seeing the same using VCP1345 macOS Sierra aka 10.12.5, but only with the Deep Select tool, however it is selecting a face not a thread.
If I use Concept Explorer on the Part, and select the Thread_xxx operation, all is OK again.
Mike
PS You can see the Pitch & Length in the top menu input areas, just not in the inspector at that point.
Edited by user Monday, July 03, 2017 2:50:27 AM(UTC)  | Reason: Not specified
thefro
#15 Posted : Monday, July 03, 2017 11:17:27 AM(UTC)
Quote
thefro
Hi Mike
Yes it is behaving in the same way, just highlighting a minor bug that may be missed
Best Regards
Brian
24c
#16 Posted : Tuesday, July 04, 2017 5:40:50 PM(UTC)
Quote
24c
Hi Tim,
Just thanks for doing this thread option, as it's mighty useful even as it is, especially for making a quick 3D model for my 3D printer.
By tweaking the diameters of the cylinders, and applying the thread operation to this, I can even allow for material shrinkage when the print cools.
I really don't miss the spiral path workaround I've been using all these years. :)
Pics are a quick and dirty test part, that took less than 5 minutes to draw and save as an STL for the printer.
Edited by user Tuesday, July 04, 2017 5:42:53 PM(UTC)  | Reason: Not specified
24c
#17 Posted : Wednesday, July 12, 2017 4:13:38 PM(UTC)
Quote
24c
Hi Tim,
Just an unexpected behaviour, I drew a short rod, about 12mm long, then applied a 0.5mm thread pitch to it, which was a default 12.7mm long. I went back to the model, and using Concept Explorer, changed the extrusion length of the rod to say 30mm, and the thread disappeared from the displayed item.
Pics for reference
Mike
macOS 10.12.5 & ViaCAD 1347
Edited by user Wednesday, July 12, 2017 4:16:27 PM(UTC)  | Reason: version & OS
24c
#18 Posted : Saturday, July 15, 2017 12:02:57 AM(UTC)
Quote
24c
Hi again,
As I hadn't got a comment, I'd thought I'd try this again, and it worked OK this time, which is so weird.
Surprised, I did some digging, & I found out what was happening...if you apply a MOVE FACE, and alter the thread in Inspector or use UNDO the external threaded portion might disappear
Likewise, if you take the model, and change the extruded length, as in make longer, the threads disappear, and if you use UNDO the model reverts to its original length, but the threads still do not reappear.
Also if you apply, and internal thread to an external face, and then try and change it back to external, nothing happens, it stays as an internal thread. If you undo & re-apply or delete the feature from Concept Explorer & re-apply as an external thread that's fine.
There is no internal or external label for these thread forms in Inspector either, would it be useful , and could this be used to switch back
Hope this helps, and clarifies.
Mike
Edited by user Saturday, July 15, 2017 12:05:24 AM(UTC)  | Reason: grammar
m10x1-int-ext-thread.vcp (2,775kb) downloaded 1 time(s).
Quick Reply Show Quick Reply
You can post new topics in this forum.
You can reply to topics in this forum.
You can delete your posts in this forum.
You can edit your posts in this forum.
You can vote in polls in this forum.
