Testing Shark Before Purchase
Thanks: 14 times Was thanked: 27 time(s) in 23 post(s)
Morning, I wanted to test the catia v5 and NX functions of shark, with a view to buy it, but the trial download doesn't have the function to do it? How can I test it please? I want to look at how the history is stored in the files once imported/exported. Thanks
ViaCAD Pro 10 + Power Pack Pro Shark CAD + Power Pack Pro Windows 7 Pro- MSI GL72 6QC-32GB RAM
Thanks: 20 times Was thanked: 36 time(s) in 32 post(s)
Catia v.5 files import as an ACIS solid, didn't have an NX file to try.
Edited by user Friday, July 14, 2017 5:39:11 AM(UTC)
(110kb) downloaded 16 time(s). You cannot view/download attachments. Try to login or register.
Hi thanks for the reply, could you export it as a V5 and post here for me to try in Catia? Thanks
Here is the exported Catia v5 file. Just remove the .sfx extension.
Edited by user Friday, July 14, 2017 10:37:23 AM(UTC)
Exported .CATPart.sfx
(396kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
Hi Thanks for the file, I can't open it in Catia V5 R21. I just get an error. Trying to check the Catia Version of it I don't any results. Is there an option to pick which version to export too? Thanks for the help!
The only options are Selected Only, which is the one I sent.
Checked file size without Selecting, same as with Select.
Multi file produces an error, probably because of just one object.
(53kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Hi, Just wanted to add I've had my IT guy load Catia V5 R24, and R26 on my laptop and I still can't open this file. Any ideas anyone? Cheers
Sorry.I want to help you.But i have no idea.
Edited by user Wednesday, September 27, 2017 8:13:29 PM(UTC)
Spatial is also Dassault Systemes, so CATIA imports ACIS .sat files anyway. The CATIA/NX/ProE/Parasolid interop is primarily for the benefit of import into Shark rather than export, all of those programs import .sat and STEP, exporting the proprietary formats doesn't carry history or feature tree, there's no innate benefit.
Ok cheers, we only have certain licenses and most of the time not the step license, so it would need to be a proper catpart, but it doesn't explain why I can't load the file in? Cheers
