jeant
#1 Posted : Wednesday, July 12, 2017 1:00:12 PM(UTC)
jeant
Hello everybody.
I have to export an isometric 3D view to illustrator. I am well able to recover my file in illustrator, but the curves and circles are cut into smaller lines. I tried not to choose the option "Polylines" in the draft view, but then the export always fails. Do you have a solution so that I can recuperate continuous curves in illustrator ? Thanks in advance for your help.
jeant attached the following image(s):
Capture d’écran 2017-07-12 à 20.48.09.png (22kb) downloaded 3 time(s).
#2 Posted : Wednesday, July 12, 2017 2:51:54 PM(UTC)
Was thanked: 55 time(s) in 53 post(s)
Hello
Did you try exporting as dwg?
Windows 10, Win 7
jeant
#3 Posted : Wednesday, July 12, 2017 3:13:09 PM(UTC)
jeant
Hello Jason,
It was a good idea, but unfortunately it does not work. I tried DWG, DXF, EPS .... no curves :-(
