Import/Export
JPEG (and BMP) export makes empty files
I am sure I have done this in the past, but today the JPEG or BMP files I export have no visible content, although the BMP files are 4,096K in size.
I have tried with and without "selected only" checked... help please...
This is a ViaCad 2d/3d V9 install.... (trying to attach a sample drawing)
thanks
Malcolm
cushion1.vc3
(14kb) downloaded 7 time(s). malcolmD attached the following image(s):
(28kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Hello Malcom
I was able to export both bmp and jpg files. What build of V9 are you running? You can check if you are on the latest build in the help menu current version.
(64kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi, yes you have the right drawing...thank you ViaCad reports that I am running the current version, and said it is Version 9.0.9 Build 1184 M
Thanks: 20 times Was thanked: 49 time(s) in 36 post(s)
raster export does probably rely on the
OpenGL support of the used graphics card driver, does printing work?
Which platform, operating system, graphics card, driver version? => if Windows: "Windows+R > dxdiag > Display"
Norbert
Norbert
Yes printing works...
Malcolm Where are you exporting files to? What file location? Thanks Jason
I was exporting them to a directory on local C drive (a project-related file)
Malcolm Are you still not able to export bmp and jpg? Have you tried different files? Regards Jason
Import/Export
