Holzwurm56
#1 Posted : Sunday, July 9, 2017 11:16:55 AM(UTC)
Holzwurm56
Hello,
i create a plane with lines and curves. Then i want extrude this plane to a solid. When i marker the plane i get the message (German version): "Rohrprofil enthält überlappende Kurven. Entfernen Sie die Kurven." I find no überlappende Kurven. Its possible to show or repare the überlappende Kurven?
Many thanks for every answer
Hans
#2 Posted : Sunday, July 9, 2017 3:53:14 PM(UTC)
Hello Hans
Try the Repair Profile tool. This will show gaps and overlaps.
Screen Shot 2017-07-09 at 4.53.01 PM.png (272kb) downloaded 5 time(s).
Holzwurm56
#3 Posted : Monday, July 10, 2017 2:44:42 PM(UTC)
Holzwurm56
Hello Tim,
many thanks for your fast answer. I have not the professional version and in my "normal" version i can not found this toolbox.
Hans
#4 Posted : Monday, July 10, 2017 3:10:06 PM(UTC)
The Repair Profile tool is in ViaCAD and Shark v10.
If you have V9 or older, would it be possible to post a file with the lines and curves for us to look at?
#5 Posted : Tuesday, July 11, 2017 7:24:17 AM(UTC)
When you make first a cover surface should it work everytime. This problem with the gaps i have never seen since i use the cover surface tool.
There is a unofficial german version Shark Cad 10 in the beta download archive.... I don't know how secret this version is.
But the curve repair tool is a good thing, Thanks for it. But beware when you wanna make a 3d surface it will change the 3d curves to a plane.
But i create my profiles with draftboard. Maybe this is also a reason why it everytime works. Maybe the profiles have to be 100% planar and shark is sometimes not precisely enough.
Edited by user Tuesday, July 11, 2017 7:42:56 AM(UTC)  | Reason: Not specified
#6 Posted : Tuesday, July 11, 2017 3:01:20 PM(UTC)
Yes, sorry forget to mention. The tool is for planar profiles and not only checks for gaps and overlaps but curve out of plane. It will project everything into a best fit plane.
Holzwurm56
#7 Posted : Saturday, July 15, 2017 12:27:21 PM(UTC)
Holzwurm56
Hello Tim,
i use the Version 6 2D 3D. The drawing was very simple and i made it new.
Hans
