2D Drafting
destruction of the drawing after publishing personalized 3d model (#4336)
Hi Tim,
I had already sent demos on bugs in the "too model sheet" and the misinterpretation of SharkFX to write lines. And destruction of the drawing after publishing personalized 3d model.
To summarize in this demo:
Personalized attributes of the cut are destroyed after the edition of the 3d model.
Please see my demo.
http://screencast.com/t/sQUT01LhGdQb Thank you in advance.
Antoine
Thanks: 224 times Was thanked: 173 time(s) in 105 post(s)
Very good video Antoine, it shows many of the small bugs that cumulate to make our life more difficult with model to sheet :double lines, hatches, history, etc...
When you edit the solid, the model to sheet draw views are regenerated, creating new 2D entities with fonts defined by the properties settings. The happens because font attributes are tied to the 2D entities.
In build 1010, I changed the logic to try and preserve the font attribute by associating it with the 3D solid edge. Please test in the next build and let me know how it goes.
Movie showing fonts preserved after some modifications http://www.csi-concepts.com/Demo/videos/fonts.mp4 Tim
Many thanks Tim have you also tried it with the hatch? And when be available version 1010? Antoine
>>have you also tried it with the hatch? I corrected an issue where changing the hatch pattern did not update the data entry window. Do you have another example (steps to repeat) where hatch is not working? Thank you, Tim
2D Drafting
