Suggestions
Trimming solids with changing direction create a new part name
When trimming a solid and change direction with Ctrl, the part name will be destroyed. Sometimes the name is not destroyed but then works model to sheet not correctly. After resolving links are everytime a new partname created. This is now not so matter because the cutlist works not properly, but when sometimes the cutlist useable, the item-names in features list should not change when trimming.
I have not been able to repeat. Would it be possible to provide an example file just before the trim operation that repeats the error? Thanks! Tim
Sorry, i was testing now several times and was not able to reproduce this. The item with the glitch have i deleted before and replaced with a mirrored item which made short after the cut. In this file was a glitch. I used old draw views for deleting old geometry and paste the changed with the cutted item. The cutted item was in the draw views still uncutted. Strange glitch, i am not able to reproduce it because i deleted the layer with this old draw views and created a complete new model to sheet.
Edited by user Monday, July 3, 2017 10:02:10 AM(UTC)
Suggestions
