Suggestions
Shark CAD can't remember the Print Setup
When restarting the program the print setup will be resetted to the standard printer, this is on my main system the pdf creator. A good was will be, Shark CAD save the print setup to the file and not to the main setup. Otherwise i can change the standard-printer in windows, but most time i print with the PDF Creator and under Windows is the changing of standard printer a little bit annoying.
Edited by user Sunday, July 2, 2017 2:28:17 AM(UTC)
Suggestions
