xMack
#1 Posted : Saturday, June 24, 2017 2:54:04 AM(UTC)
xMack
Is there a way to convert a top level layer to a sub layer and move it under a different top level layer? For example, I started on an airplane design and I created layers for various sections like fuselage, wings, horizontal stab, vertical stab, etc. As I started adding more details I decided it would be better to make those layers sub layers under a new top level layer called airframe. Is there an easy way to do this?
Thanks. XMack
thanks 1 user thanked xMack for this useful post.
MPSchmied on 6/24/2017(UTC)
#2 Posted : Saturday, June 24, 2017 5:26:56 AM(UTC)
This is a very good idea. For layers have i more ideas like Sort in alphabetical order and Layername = Feature (Part)-Name and Multirename and Multidelete, Hiding Layers permanently (show not when use the command "Show all") etc.
Edited by user Saturday, June 24, 2017 5:30:12 AM(UTC)  | Reason: Not specified
#3 Posted : Saturday, June 24, 2017 7:02:36 PM(UTC)
Yes xMack, a very good idea : When I import files I need to move some imported sublayers to other levels.
Today I recreate the layers and move the elements to them...
Problem : it's impossible to move many elements with history to another layer at once !
It seems that the links loose reference during movement :-(
Often ends up into a big mess.
#4 Posted : Saturday, June 24, 2017 7:04:57 PM(UTC)
That was me, your guest !
