If you select an item and perform a 3 point rotate, you can then input a number and it will snap to that angle. If you do the same thing to a group, it does not move.
I have attached a file, the bottom item is a group.
Art
Mac 10.12.5
SharkCad Pro 10 1335
Rotating Groups.sfx
(117kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
i can confirm that problem in build 1342 Mac beta. seems to be a bug
Thanks, Any PC Users have the same problem? Art Mac 10.12.5 SharkCad Pro 10 1335
ViaCAD 10 Pro for Win (7 Pro) works fine with the grouped 3-p-rotation, but a similar problem extists with groups (tested with Polar Duplicated cylinders). It is not possible to pull up the body of the group, the pull-up-tool knows only single surfaces (here: top of a cylinder - 1 of 8) - no reflexion to the group. The same - also multi choice is not possible with the pull-up-tool. (Info-text: Selected curves can move region) Best regards horst.w, GER
