#1 Posted : Thursday, June 15, 2017 12:01:54 PM(UTC)
Hi can anyone convert SketchUp to solid Model I have 5 files some simple some more complex.
Derek
#2 Posted : Friday, June 16, 2017 11:24:55 AM(UTC)
Was thanked: 189 time(s) in 167 post(s)
Hello Derek
PowerPack Pro can convert SketchUp files, some examples below.
http://www.masterviacad.com/videos/page64/index.html
If you post one that I can use to make a video, I'll take a shot at converting.
ViaCAD/Shark Development Team
Links to ViaCAD Resources
DerekBr0wn
#3 Posted : Friday, June 16, 2017 4:40:09 PM(UTC)
DerekBr0wn
This is a real difficult one. On my Sketch Up it looks great when I send or export it to DXF or DWG or OBJ it has problems. If it looks like you can do something with it but cannot overcome the flaws I will redraw it. It has had so many small changes that I think some errors have crept in.
Actually I will send two files Carriage (difficult) and CarriageComponentMount In Skp, DWG and DXF
CarriageComponentMount.dwg (854kb) downloaded 5 time(s).
CarriageComponentMount.dxf (3,594kb) downloaded 4 time(s).
DerekBr0wn attached the following image(s):
DerekBr0wn
#4 Posted : Friday, June 16, 2017 5:37:10 PM(UTC)
DerekBr0wn
Other File
#5 Posted : Friday, June 16, 2017 9:40:40 PM(UTC)
If the attachment is not uploading, try zipping and uploading.
#6 Posted : Saturday, June 17, 2017 8:42:52 AM(UTC)
Other file zipped Thanks Tim. I must say that this is a very frustrating user group I have spent hours with it. It seems to just lock up. I'm giving up the will to live here
Carriage.zip (1,898kb) downloaded 9 time(s).
#7 Posted : Saturday, June 17, 2017 10:58:44 AM(UTC)
Can you private email the Sketchup file if unable to attach it?
The DWG files download fine but are exploded. The sketchup file should retain the components.
rockyroad_us
#8 Posted : Saturday, June 17, 2017 12:01:38 PM(UTC)
rockyroad_us
looks like your dwg exporter is converting the meshes into lines so you get both meshes and lines. Try to export just the model without the text too since the import sees more than one mesh.
Alternatively, export in .stl.
Tim, how about a video of your findings. Despite closing the mesh, the subD to NURB crashes pro CAD10.
I personally don't like to work in mesh but lately I've been getting lots of clients sending me .stl files and need to figure out the power pack tool well enough.
Edited by user Saturday, June 17, 2017 12:58:34 PM(UTC)  | Reason: more info
FX 9-1224 Pro10-1369
OSX.11.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
