Converting Google SketchUp files to Solid Works
Hi can anyone convert SketchUp to solid Model I have 5 files some simple some more complex. Derek
Hello Derek
PowerPack Pro can convert SketchUp files, some examples below.
http://www.masterviacad.com/videos/page64/index.html If you post one that I can use to make a video, I'll take a shot at converting.
This is a real difficult one. On my Sketch Up it looks great when I send or export it to DXF or DWG or OBJ it has problems. If it looks like you can do something with it but cannot overcome the flaws I will redraw it. It has had so many small changes that I think some errors have crept in.
Actually I will send two files Carriage (difficult) and CarriageComponentMount In Skp, DWG and DXF
CarriageComponentMount.dwg
(854kb) downloaded 5 time(s). CarriageComponentMount.dxf
(3,594kb) downloaded 4 time(s). DerekBr0wn attached the following image(s):
(41kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
If the attachment is not uploading, try zipping and uploading. Tim
Other file zipped Thanks Tim. I must say that this is a very frustrating user group I have spent hours with it. It seems to just lock up. I'm giving up the will to live here
Carriage.zip
(1,898kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Can you private email the Sketchup file if unable to attach it? The DWG files download fine but are exploded. The sketchup file should retain the components. Tim
looks like your dwg exporter is converting the meshes into lines so you get both meshes and lines. Try to export just the model without the text too since the import sees more than one mesh.
Alternatively, export in .stl.
Tim, how about a video of your findings. Despite closing the mesh, the subD to NURB crashes pro CAD10.
I personally don't like to work in mesh but lately I've been getting lots of clients sending me .stl files and need to figure out the power pack tool well enough.
Edited by user Saturday, June 17, 2017 12:58:34 PM(UTC)
| Reason: more info
