Surface Modeling
Cannot "extrude surface" of a polygon
Shark FX 9.0.13 Build 1216 Mac OS 10.11.6 I can extrude surface of a circle etc but not a polygon, have I not had enough coffee? Thanks in advance, Art
Thanks: 195 times Was thanked: 163 time(s) in 112 post(s)
Might be a Mac issue, works O.K. on Win 10 PC Shark FX9 1216. Larry
OK, now I am on 10.12.5 on a Mac and Shark Pro 10 1335 and I still cannot extrude a polygon (7 months later). The manual does not mention extruding a polygon. Is this something broken or deliberate? Thanks, Art
Art
Seems ok on Windows. What is the polygon? Can you attach a sample file with one in it.
Edited by user Wednesday, June 14, 2017 10:07:28 AM(UTC)
Well, Not much to it, just a rectangle. In order to extrude a surface I have to change it to lines, which works, it extrudes like a polygon, it just seems silly.
Art
Edited by user Wednesday, June 14, 2017 10:46:51 AM(UTC)
polygon.sfx
(4kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
If you 'Select All' and 'Extrude', nothing seems to happen, hit 'Enter' and it extrudes. Larry
Sorry, I do not know how to do that. Where is "extrude"? So are you saying that it works? Do I have to hide everything else?
I am using the "extrude surface tool", the extrude solid works fine.
Art
Edited by user Wednesday, June 14, 2017 11:15:02 AM(UTC)
Hello Art I am unable to repeat on Mac or Win. When using the Extrude Solid :Vector option, does the polygon turn red when selected? Tim
Yes, the extrude solid works perfectly.
The "Extrude Surface" does not allow selection.
Art
Is there anything you want me to send you? It happens on every file, and has for over 7 months.
Edited by user Wednesday, June 14, 2017 12:34:24 PM(UTC)
Art Are you using the push pull tool? Regards Jason
Repeated, found and fixed. I was not checking the correct tool!
(48kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Surface Modeling
