tedems
#1 Posted : Monday, May 22, 2017 9:51:37 AM(UTC)
tedems
Somehow i turned on visible control points 3d and 2d for objects created. I cannot turn off the Visible control points except when the object is selected. Is there a way to setup VCPro 10 to control the behavior globally and not per object selected? Is there a keyboard shortcut that turns this on and off?
any help would be appreciated
thanks
#2 Posted : Monday, May 22, 2017 10:52:31 AM(UTC)
thanks
Hello
Ctrl+D toggles control points It is also in the edit menu --> show points
rokoko
#3 Posted : Monday, May 22, 2017 11:07:59 AM(UTC)
rokoko
deselect all objects (nothing should be selected) and uncheck menu -> edit -> show points to get the default setting.
