rokoko
#1 Posted : Saturday, May 20, 2017 2:58:11 PM(UTC)
rokoko
i tried to move 4 faces (which have been selected by deep select tool) simultaneously with the gripper.
when entering a distance after a first move with the gripper, the new value is added to the first move. this is a bit unexpected, because a data entry after a move should set the entire distance just as if only one face is selected.
build 1337 mac
horst.w
#2 Posted : Sunday, May 21, 2017 2:20:24 PM(UTC)
horst.w
It's the same with Win 7, but using the "normal" Select-tool the movements are not added.
horst.w, GER
